Date/Time: Sat, 26 Sep 2026 11:35:13 +0000
stability issue
View Count: 2980
[2013-04-03 19:40:25]
User70302 - Posts: 30
Until now, I was running a chartbook with a quoteboard (10 symbols) and some charts and everything was stable. Recently I added another quoteboard window to that chartbook with some 50+symbols in it. Now, after around 30 minutes SC becomes unstable (this is repeatable). Its not freezing up but rather all windows start to dissapear/fluctuate. I am running SC959 with IB.
[2013-04-03 19:47:16]
Please provide us the Chartbook and we will test it. Here are the instructions:
https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile
This sounds like it is a GDI leak. Please go to the Windows Task Manager. Go to the Processes tab. Add the GDI Objects column (View >> Select Columns). See if it continues to increase for the SierraChart.exe process
Date Time Of Last Edit: 2013-04-03 19:56:36
[2013-04-03 20:34:02]
Please do take note of the paragraph in the prior post about a GDI leak. We are interested to know if this is the case. If so, we can resolve very quickly.
[2013-04-03 23:30:36]
I looked it up and yes, GDI is increasing for sierrachart.exe. It increases around 4 points every second.
[2013-04-03 23:36:19]
Can you provide us your Chartbook so we can test. Instructions:
You can also send it to support AT Sierra Chart.com.
Date Time Of Last Edit: 2013-04-03 23:37:40
[2013-04-04 04:00:04]
This is now resolved. Please update by selecting Help >> Download Current Version.
