Date/Time: Thu, 23 Jan 2025 15:12:59 +0000
IB moving average
View Count: 775
[2017-08-24 08:19:15] |
User275648 - Posts: 8 |
Hi, I would like to have a study which calculates an initial balance range, just like ATR but only for the first 60 minutes of each session, is that available? |
[2017-08-24 14:12:35] |
You can use the Initial Balance study or the High/ Low for Time Period study: Initial Balance High/Low for Time Period You can then calculate the range by using Study Subgraphs Subtract/Difference: Study Subgraphs Subtract/Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
