Date/Time: Wed, 15 Jan 2025 15:26:09 +0000
Order Window
View Count: 834
[2017-08-23 23:38:47] |
User639764 - Posts: 2 |
I have my order window detached from my chart but it's quite large. How can I shrink it / customize it's size?
[2017-08-24 05:08:13] |
The easiest thing to do is to select the C tab on the Trade Window. Also refer to: Graphics Settings: Adjusting Size of Dialog Windows Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
