Date/Time: Wed, 15 Jan 2025 15:19:32 +0000
Is it possible to link a dom with a chart?
View Count: 772
[2017-08-23 19:02:29] |
User375110 - Posts: 28 |
SC: Is it possible to have a trading dom come to the front if clicking on a chart in a chartbook with the same symbol? If so, can it be done even if the trading dom is minimized? By a trading dom, I mean the stand alone dom that SC has. |
[2017-08-23 21:53:41] |
No, this is not supported.
