Date/Time: Wed, 15 Jan 2025 19:53:16 +0000
Minimize and Restore behaviour
View Count: 756
[2017-08-23 16:28:03] |
SSS - Posts: 16 |
Dear Support, I have charts set up in a certain size, and a certain location within the chartbook. If I minimize a chart, and then later double click its tab, it re-opens MAXIMIZED, filling up the entire chartbook space. I can only get it to its original size and location if I click "Restore Down" on the chart window. Is there a setting to change this behaviour, so that when I double-click the tab of a minimized chart, it re-opens to its original size and location instead of opening fully maximized? Thanks in advance. |
[2017-08-24 05:10:57] |
We will look into this.
[2017-09-08 08:51:55] |
A solution to this has been implemented in the latest prerelease.
