Date/Time: Wed, 15 Jan 2025 15:46:28 +0000
sc.GetOrderByIndex does not return any orders when trading live to Interactive Brokers
View Count: 1002
[2017-08-23 04:10:16]
jseppa - Posts: 18
I'm not able to see any orders when I connect my study to live trading feed, however it works fine with simulated trading.
The following code returns nothing when I create a real order directly on the chart (using trading chart dom):
while (true)
    s_SCTradeOrder OrderDetails;
    if (sc.GetOrderByIndex(Index, OrderDetails) == SCTRADING_ORDER_ERROR)
      break;
    Index++; // Increment the index for the next call to sc.GetOrderByIndex
    // Log the order
    logOrderDetails(sc, OrderDetails);
however when I enable "Trade Simulated Mode on" and create an order in the same way, it works fine:
Chart: JD [M] 5 Min #1 | Study: Test Function | id=[751938] pid=[751937] [Sell] [Stop(2)] [Pending Child-Client(3)] qty=[0] [JD] price=[41.31] | 2017-08-23 00:06:32 *
Chart: JD [M] 5 Min #1 | Study: Test Function | id=[751937] pid=[0] [Buy] [Limit(1)] [Open(5)] qty=[1000] [JD] price=[41.81] | 2017-08-23 00:06:32 *
Am I missing a setting somewhere? I've set the following:
sc.SendOrdersToTradeService = true;
Cheers,
Jason
[2017-08-23 04:43:52]
jseppa - Posts: 18
It turns out setting
sc.FreeDLL = false;
fixed my issue. Cheers
[2017-08-23 21:47:55]
For non-simulated orders this does need to be set:
We do not see how what you describe in post #2 is related. That will make absolutely no difference.
[2017-08-23 22:21:00]
jseppa - Posts: 18
yeh I don't know what happened. That's the only thing I changed, I restarted the application, and it started working.
I'll try to reproduce
