Date/Time: Wed, 15 Jan 2025 16:07:19 +0000
Delta is wrong in Sierra
View Count: 1576
[2017-08-22 18:45:20] |
John York - Posts: 1 |
I've been in the process of changing over from Investor RT to Sierra. The only thing keeping me with Investor RT is the delta signals i've made over there have accurate delta. The delta with Sierra doesn't seem to be accurate or match my delta in IRT, or match other's delta. Me and my buddy have made some delta signal charts in Sierra and he matches my old IRT chart but my chart is way off. Can you please help? Data: OEC/Gain |
[2017-08-22 18:56:19] |
This is a known problem with OEC data. We are going to post this on the Gain Capital/ OEC page now so others know about it. You will need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-22 18:56:35
[2017-08-22 19:01:01] |
This is now documented here: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#Included Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
