Date/Time: Wed, 15 Jan 2025 16:26:04 +0000
Some studies starting at midnight, instead of chart start time (globex) How to adjust?
View Count: 836
[2017-08-22 16:37:59] |
navigator - Posts: 27 |
Studies like Cumulative volume delta, are using midnight as start of day, instead of specified chart start time.
[2017-08-22 18:29:47] |
With the Cumulative Delta Bars studies, set the Reset at Start of Trading Day Input to Yes. And make sure the Session Times for the chart are set as you require: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-22 18:29:56
