Date/Time: Wed, 15 Jan 2025 16:06:13 +0000
Reload and Recalc
View Count: 909
[2017-08-22 12:44:49]
infpz - Posts: 826
Is this normal? I enter values into K3 and then hit reload and recalc and my formula disappears. Version 1600.
[2017-08-22 12:51:50]
No, not normal. This would mean that the Formula Source Sheet Number Input is not set correctly. Refer to:
Spreadsheet Study Inputs: Formula Source Sheet Number
[2017-08-22 12:56:04]
infpz - Posts: 826
OK. I deleted the sheet and removed and re-added the Spreadsheet System for Trading Study. The field in question defaults to Sheet 4. Which is how the prior one was showing. Is that a default I put in place inadvertently?
[2017-08-22 13:43:28]
This input will be set to the same as the Chart Number by default.
Make sure you are looking at Sheet 4. Is the formula still clearing from the cell?
Date Time Of Last Edit: 2017-08-22 16:05:55
[2017-08-22 13:44:25]
infpz - Posts: 826
Will test. Thx.
