Date/Time: Wed, 15 Jan 2025 16:14:24 +0000
Continuous Futures Contract for UM (BMF)
View Count: 790
[2017-08-22 12:27:03] |
Marcelo - Posts: 13 |
Hi Support, I am facing issues to have my UMV17 contract (BMF) as a continuous futures contract. I have tried all 4 types of continuous contract available and I only get the current one, the UMV17. X4U17, which comes from the same exchange (BMF) doesn't seem to have the same issue. I use Sierra Chart Exchange data feed and haven't made any adjustments in the Symbol Settings. Can you please check if you have the same issue? |
[2017-08-22 19:29:05] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Symbol Settings Go to the UMV17 chart and select Chart >> Reload and Recalculate. You will need to use one of the Volume-based rollover options since we cannot define the rollover rule accurately with this. It is an unusual rollover condition. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
