Date/Time: Wed, 15 Jan 2025 15:48:19 +0000
Spreadsheet J28 (Disable Auto Trading) cannot disable Auto Trading
View Count: 1264
[2017-08-22 05:24:09]
User841591 - Posts: 42
I want to use a value of Subgraph (output 1 or 0) to disable/enable the Auto Trading in a spreadsheet and refer the J28 to equal this value e.g.(=AU3), but it is unable to disable the Auto Trading even though the subgraph output value is 1. Pls note it can work when I manually edit 1 in J28 and I have checked the "Trade simulation" is off and "Auto trading" is on and "Send order to Trade Service" is 1. Pls kindly advise how to fix it.
[2017-08-22 05:36:59]
There should be no problem with this if you actually see the formula returning in cell J28 an actual numeric 1.
Make sure the Subgraph contains an actual numeric 1 and not text.
[2017-08-24 15:20:22]
I find it works in case I refer J28 to the row4 value of the subgraph. Is it the reason that I select "Signal Only on Bar Close" and I need to refer to the value of row4 instead of row3?
Date Time Of Last Edit: 2017-08-24 15:21:16
[2017-08-25 03:30:21]
We do not know the answer to this question because we do not know what the cell J28 is referring to, actually contains at the time of an order signal.
Date Time Of Last Edit: 2017-08-25 03:30:53
[2017-08-25 11:45:40]
Sawtooth - Posts: 4152
The 'Signal Only On Bar Close' setting only affects the Formula Columns. Formulas in other columns must reference row 4 to be at close of bar.
