Date/Time: Wed, 15 Jan 2025 16:18:45 +0000
Cannot overwrite the old dll files after Remote Build
View Count: 1066
[2017-08-22 02:16:07] |
User841591 - Posts: 42 |
I get the error message below after pressing Remote Build. I need to close the SC and delete the old dll file manually and then compile successfully. Any suggestion that I can re-build the dll after code change without this manual steps. Writing file to: C:\SierraChart\Data\MyTradeSys.dll Failed to save the file C:\SierraChart\Data\MyTradeSys.dll. Error opening file. Error: Windows error code 32: The process cannot access the file because it is being used by another process. -- End of Build -- 10:03:11 |
[2017-08-22 05:42:09] |
Refer to: Advanced Custom Study Interface and Language (ACSIL): Modifying Advanced Custom Study Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
