Date/Time: Wed, 15 Jan 2025 16:18:08 +0000
message log
View Count: 602
[2017-08-22 00:50:50] |
User157806 - Posts: 71 |
Is it possible to disable the message log so it does not auto populate every time a log or message comes in?
[2017-08-22 01:20:12] |
No. It should not be a problem and under normal conditions that should not be opening. If it is opening unexpectedly we need to see what the messages are. Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-22 01:25:45
