Date/Time: Wed, 15 Jan 2025 15:58:50 +0000
Possible bug in volume by price
View Count: 680
[2017-08-21 19:37:40]
traderacademie - Posts: 38
In study Volume By Price, input name 'Display Volume in Bars', I set it to 'Number of trades'. Then when the chart is set to e.g. 15 min timeframe, and the price moves from 1 price to another, the number of trades are updated across multiple prices and are corrupted it seems.
[2017-08-21 19:41:17]
You need to follow through the Volume by Price study instructions here:
Volume By Price Study: Step By Step Instructions
Be sure to follow the step to set Sierra Chart for a tick by tick data configuration.
[2017-08-21 19:47:37]
yes I have done all this, and still this happens, the only timeframe it doesn't happen is when I set it to 'Number of trades per bar' with a value of 1
Date Time Of Last Edit: 2017-08-21 19:47:58
[2017-08-21 19:55:42]
Here are the instructions to set Sierra Chart to a tick by tick data configuration:
Verify that you do indeed have tick by tick data.
There is zero percent chance the study contains a bug like this. This is technically impossible.
Provide an image of the chart or Trade DOM, by following these instructions:
[2017-08-21 20:08:28]
I even get it in replay mode. I'm on CQG Web API and I'm using Sierra version 1599 (prerelease).
from my observations it seems that the price levels that are within the current bar all updated at the same time.
here is the image
http://www.sierrachart.com/image.php?Image=1503345961515.png
[2017-08-22 00:27:56]
OK, we see the problem. This is just affecting the Number of Trades. There was a problem where the prior number of trades was not being subtracted on a chart update.
This will be resolved in the next release.
