Date/Time: Wed, 15 Jan 2025 16:20:15 +0000
OEC cumulative delta is very different from other feed
View Count: 883
[2017-08-21 18:25:05]
fuzzy - Posts: 7
In the image, left is CQG and right is OEC. Is it the data feed problem or SC problem?
Date Time Of Last Edit: 2017-08-21 18:26:53
imageCapture.PNG / V - Attached On 2017-08-21 18:23:45 UTC - Size: 55.92 KB - 259 views
[2017-08-21 18:45:59]
fuzzy - Posts: 7
Here is an image comparing CQG (left) and SC historic data (right, delayed), it's clear they are very close. So OEC has problem.
Date Time Of Last Edit: 2017-08-21 18:48:40
imageCapture1.PNG / V - Attached On 2017-08-21 18:48:33 UTC - Size: 53.02 KB - 250 views
[2017-08-21 19:47:41]
This is a known OEC data problem.
You can use CQG or use the Sierra Chart Exchange Data Feed:
