Date/Time: Wed, 15 Jan 2025 15:58:05 +0000
tool configuration
View Count: 1074
[2017-08-21 18:23:24] |
User807026 - Posts: 86 |
I am trying to configure a the Volume by price study and I saved my configuration as TC-1. But I just noticed that my TC-1 button on my main toolbar is grayed out and when I press the DVP button I get the standard default profile and have to change it by hand which is very time consuming. The TC 1-8 system is very confusing to me anyway, I have really never understood it no matter how much I read of your help with it. How can I get a different configuration saved to use?
[2017-08-21 20:06:36] |
What version of Sierra Chart are you running? For TC1 to be enabled, you do have to first select Tools >> Draw Volume Profile. And then you choose the tool configuration (TC1) after and before using the tool. Here is the documentation for this: Volume By Price Study: Step by Step Instructions to Configure the Draw Volume Profile Tool Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-21 20:06:54
