Date/Time: Wed, 15 Jan 2025 15:44:14 +0000
Futures symbols and data feed
View Count: 1104
[2017-08-21 16:43:27] |
User877884 - Posts: 3 |
I have a funded account with AMP/CQG.........I'm going to want to trade both FX and Futures.......2 questions....where do I go to find the futures symbols SC uses and how do I get the data feed from AMP/CQG? I'm going to want to trade from the SC platform.......... Thank you, Frank Date Time Of Last Edit: 2017-08-21 18:42:32
[2017-08-21 19:27:07] |
Did you want to trade spot FX? Does AMP have a service for US customers to trade spot FX? Follow the CQG setup instructions here: CQG Trading Platform Service: Setup Instructions The future symbols are listed in File >> Find Symbol >> Futures. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-21 19:28:56
[2017-08-24 02:56:51] |
Am I only allowed to open my charts on one computer at a time? Thanks, |
[2017-08-24 03:12:26] |
No. You can use Sierra Chart on two computers at the same time but an external service may limit you to one connection at a time.
[2017-08-24 03:16:05] |
I just signed up for the Sierra- CQG data feed........will that allow second computer or have I screwed up? Thanks again.........
[2017-08-24 03:52:30] |
CQG only allows one connection to their server at a time using a particular CQG username.
