Date/Time: Wed, 15 Jan 2025 15:46:02 +0000
Again with FXCM CFD Symbols with [M], but it connects this time
View Count: 1039
[2017-08-21 09:47:51]
AlexPereira - Posts: 197
Upon updating to 1599 release, I again have CFD symbols with [M]. I am able to connect, and i think trade ( at least it seems so ).
I already did an "Update from server" and "Full Reset" on the symbols definition, disconnected, connected and restarted SierraCharts also.
The only thing that might hint of whats happening is ( in example for NAS100 symbol ) :
HD Request # 5 | Re-requesting historical data for NAS100 to get the latest data since the download was started while not connected to primary service. | 2017-08-21 10:45:03
Is this a problem or does FXCM CFD Symbols will now always have an [M] ?
Thanks.
[2017-08-21 13:05:41]
They should always have a [M]. If the Forex or CFD symbols do not, this is a problem.
[2017-08-21 13:27:56]
Completly puzzled here. They never had before, its the first time they do ! Did anything change in the FXCM connection ?
Also, in LMAX with Forex, they don't have an [M]. Its an FXCM thing only, right ?
[2017-08-21 13:42:12]
Actually, thinking about this some more you are right.
With the way that those FXCM DTC services are implemented, there should not be a [M]. The way that those market data subscriptions are routed is not through one of the sub services.
What is Global Settings >> Data/Trade Service Settings >> Service set to?
[2017-08-21 13:45:05]
Service: FXCM Live Trading (Standard) - DTC [trading]
Server: FXCM LTD EURCFDREAL Server
[2017-08-21 13:56:31]
This will be resolved in the next release but it does not matter because the source of the data still remains the same.
[2017-08-21 13:59:25]
OK.... using it it does seem to be working properly.
I was just alarmed with the previous week problem I had, where I could not connect after [M] appearing. ( relevant ticked: Cannot connect to FXCM account and symbols now have a [M] in them )
Thanks for the help !
[2017-08-21 18:15:48]
BTW, confirm that it is working on release 1600 !
[M] no longer appears and feed is working.
Thanks !
