Date/Time: Wed, 15 Jan 2025 16:03:47 +0000
User drawn volume profile - VWAP+SD bug
View Count: 1159
[2017-08-20 19:30:26] |
Zdislav - Posts: 73 |
I am still using version 1568. When I draw volume profile using the tool and adjust the period, everything draws just fine and very quickly. An only annoying thing is the VWAP standard deviation lines. They stay in the graph drawn as the longest period boundaries the selected volume profile set previously. Even after boundaries modification. Until now I just got over it, but it starts to mess my graphs up. Has this issue been solved in versions later then 1568? Thank you. Z. Please see attached picture which shows the bad behavior on basic clean chart. http://www.sierrachart.com/image.php?Image=1503257388452.png |
[2017-08-21 02:54:19] |
Neo - Posts: 198 |
There have been issues with VWAP using "draw volume profile" for some time now. However, it's only noticeable on equities, so it hasn't been pointed out. ^ Thought I would point this out now if SC engineering is going to be addressing a related issue. Date Time Of Last Edit: 2017-08-21 02:57:51
SPY 5 Min #16 2017-08-20 22_51_31.242.png / V - Attached On 2017-08-21 02:52:30 UTC - Size: 56.54 KB - 306 views |
[2017-08-21 13:26:37] |
We will look at both of these items.
[2017-08-23 02:43:27] |
This is now all resolved in version 1601. In regards to post #2, you should have pointed this out sooner. It is simply due to a calculation overflow and we would have resolved it promptly.
