Date/Time: Wed, 15 Jan 2025 15:38:16 +0000
VIX futures data on the chart looks bad
View Count: 848
[2017-08-20 13:24:32] |
User921987 - Posts: 238 |
How the VIX futures OHLC bar on the chart can have a body if the bar beriod is set to 1 tick (please see attached picture) ?
vix_1tick_bars.gif / V - Attached On 2017-08-20 13:23:14 UTC - Size: 52.64 KB - 294 views |
[2017-08-20 14:16:13] |
Follow the instructions here in regards to this: Number Of Trades, Volume or Range Bar Charts Do Not Match Setting or Are Not Accurate or Are Inconsistent: Repeating Bars with Number of Trades or Volume Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
