Date/Time: Wed, 15 Jan 2025 15:26:26 +0000
Expiry date
View Count: 784
[2017-08-20 10:19:11] |
User680629 - Posts: 1 |
Hi, Anytime I open the Sierra Chart platform, I keep getting the message that my Sierra chart trial will expire in three days. This can not be correct because I was initially informed through an email from accounting@sierrachart.com that my trial will expire on September 12. Please can you correct this to ensure that my trial ends as initially communicated which is on September 12. Please note that I am currently using Sierra Charts for the Oneuptrader.com evaluation. Thanks
[2017-08-20 14:18:26] |
We have extended your account. It was limited based upon prior trial time, but that determination is not necessarily always accurate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-20 14:18:45
