Date/Time: Wed, 15 Jan 2025 15:57:48 +0000
populate sierrachart from TWS
View Count: 792
[2017-08-19 16:51:25] |
doctor10 - Posts: 78 |
Is it possible to populate sierrachart with the financial instrument and weekly trade log out of TWS to retrospectively analyze trade performance. Many trades may be executed from TWS iphone app during the day without the benefit of simultaneously using the sierrachart trade processes. It would be helpful to be able to pull the previous week log off TWS into sierrachart for analysis. tnx |
[2017-08-22 05:33:06] |
Refer to: Trade Activity Log: Automatic Insertion of Missing Order Fills For Non-Simulated Trading In the case of Interactive Brokers you will also need to enable Global Settings >> Data/Trade Service Settings >> Service Setting >> Download Historical Order Fills on Connect. We also understand that there is a setting in Trader Workstation to control how many days of order fills are made available. You will need to check on that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-23 03:26:25
