Date/Time: Wed, 15 Jan 2025 16:20:10 +0000
Horizontal Line in Time Study
View Count: 1486
[2017-08-18 22:51:09] |
Crtfyd - Posts: 281 |
For future versions? It'd be nice if the Horizontal Line in Time study supported more than one minute bars! It's useless if using Tick Charts bc in one second there can be several bars (ie: 9:29:59:001, 9:29:59:013, etc), so I'm NOT getting the last price (or whatever its based on) of 9:29:59 in this case, because it only recognizes to the exact second, not beyond. If you know a workaround, I'd like to know. I thought the "displacement" would do it, if I used 9:30:00 [-1], but it only shifts the drawing, not the computation. Thx |
[2017-08-22 22:09:36] |
It does support seconds but what you really want is milliseconds support. We will add that. The Time Input for all studies will support milliseconds.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-22 22:09:58
[2017-08-22 22:24:22] |
Yes, you are right, I meant milliseconds. But I don't understand your comment that the "Time" input supports milliseconds. For instance, the Horizontal Line in Time study. I click on the Time input and only down to "seconds" will show. If I add another colon (ie: 9:30:29:59), it will not take it. It will still just mark the 9:30:29 bar, no :29 bar after that. What do you mean? |
[2017-08-23 00:55:50] |
In the next release milliseconds will be supported and what you would enter is: 09:30:29.059 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
