Date/Time: Wed, 19 Mar 2025 10:12:18 +0000
Butterfly spread help please
View Count: 1631
[2017-08-18 22:20:53] |
User358171 - Posts: 1 |
Hi, I need to know how to put the ZB ZN together as one line chart. I have tried but I get a line chart under the original chart. I want to see just the ZN ZB as one line chart. Can you please help. Thank you |
[2017-08-19 22:35:21] |
We need to understand precisely the calculation that you want to do. Do you want to calculate the difference between ZB and ZN futures contracts? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-19 23:10:50] |
User184118 - Posts: 2 |
Hi, Yes the difference between the ZB and ZN. Also a butterfly spread with thirty year, ten year, and five year. Called a Butterfly spread I believe. All futures contracts. I am using CQG data feed. Thank you |
[2017-08-21 20:19:02] |
With CQG you can use the CQG exchange traded spreads. Refer to: CQG Trading Platform Service: CQG Exchange Traded Strategies/Spreads Symbol Format You can also use the Difference (Single Line) study: Difference (Bar or Single Line) There is also the Butterfly study: Spread - Butterfly You can set either study to display as the main price graph: Chart Studies: Settings and Inputs Tab >> Display As Main Price Graph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-21 20:20:43
[2022-10-20 20:30:58] |
voided - Posts: 45 |
Hi, It would be very helpful if there were support for the native, exchange-traded butterflies, with real (and full) market depth. On this note, full market depth for MBO customers on calendar spreads would be much appreciated, as well. |
