Date/Time: Wed, 15 Jan 2025 16:06:20 +0000
Position Size Limiter Management
View Count: 1115
[2017-08-18 21:33:34] |
Jezz - Posts: 33 |
Hi Working with Profit Loss Management, found it really useful. In order to improve risk control, I would like to limit position size as well. (ie to 2 contract maximum to follow an imposed scaling plan) Is there any implemented way of doing it?, I cannot find it. If not, please consider including it in a future release. Can it be implemented as a Study? Any available Study? Is there any hook to be used by ASCIL code to prevent the order to broker? Thanks in advance |
[2017-08-21 19:54:21] |
No, this is not supported for manual trading. Only with automated trading.
