Date/Time: Mon, 28 Sep 2026 04:15:44 +0000
Different bar period for study
View Count: 3032
| [2013-04-03 19:39:26] |
| leftbrain - Posts: 7 |
Is there any way to place a study in the chart region and base it on a different bar period than the study itself? Specifically, I would like to see a 30 min weighted moving average overlayed on a 3 min chart. (I know that most would do this in separate chart windows but I have no other use for the larger time frame than to know its moving average in relation to the lower time frame price action that I am analyzing.) Thank you in advance. |
| [2013-04-03 19:50:48] |
Please refer to help topic 28 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
