Date/Time: Wed, 15 Jan 2025 15:35:35 +0000
Number bars COT
View Count: 2863
[2017-08-18 05:50:27] |
Dom7364 - Posts: 257 |
There used to be a pullback option AND a COT option to display. Where do you add the COT now? Thanks |
[2017-08-18 05:54:32] |
Do you mean the historical pullback data? This is explained here: Numbers Bars: Show Historical Pullback AskVolume BidVolume Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-18 05:58:53] |
There used to be a COT option in Chart Settings/Advanced settings, which doesn't seem to be there anymore. It would calculate 1 number, either at the bottom or top of each number bar, as opposed to 2 now, and it was 0 on one side and a nulber of the other side (COT).
[2017-08-18 13:11:52] |
The documentation we linked to explains this. Here is the link again: Numbers Bars: Show Historical Pullback AskVolume BidVolume Difference (Show Historical Pullback AskVolume BidVolume Difference) It says: For this setting to have an effect and actually display the Ask Volume and Bid Volume difference, it is necessary to enable the Historical Pullback Data for the chart in Chart >> Chart settings >> Advanced Settings. Refer to Historical Pullback Data for information about this setting and the exact meaning of the two resetting methods.
Paragraph above links to this particular section: Chart Settings: Historical Pullback Data (Chart >> Chart Settings >> Chart Data >> Chart Data menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
