Date/Time: Fri, 31 Jan 2025 03:31:16 +0000
order confirmation
View Count: 3445
[2017-08-18 02:30:43] |
User630989 - Posts: 10 |
where do i set it so my orders I must confirm before they go to be filled...
[2017-08-18 05:52:05] |
You need to enable Order Confirmations on the Trade Window. Refer to: Basic Trading and the Trade Window: Main/C >> Menu >> Order Confirmations (chart specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-04-10 13:25:44] |
nioko54130 - Posts: 108 |
hi dear support boaord! thank's for the link regarding the way we can remove the order confirmation message. Unfortunately, i have already cancelled these options on the trade window, but the SierraChart platform still continue to ask me the trade confirmation. it appears that this problem come only on the real account and not on the SIM account. thank's for your help! Nico |
[2019-04-10 18:43:35] |
Therefore, you are using the wrong Trade Window: Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM You need to use the one associated with the particular chart you are trading from. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-04-10 18:44:00
