Date/Time: Wed, 15 Jan 2025 15:31:14 +0000
Risk/Reward tool "show ticks" not displaying in Chart region 2
View Count: 1180
[2017-08-17 22:54:01] |
NumbersBars - Posts: 141 |
Version: 1598 When setting Main Price Graph to Chart Region 2, 'Show Ticks" and "Show Currency value" functions of Risk Reward tool are not working (i.e not displaying in chart region 2). I have attached the image for your reference. http://www.sierrachart.com/image.php?Image=1503009931776.png Date Time Of Last Edit: 2017-08-17 22:55:36
[2017-08-17 23:26:07] |
This is because this particular Chart Region does not necessarily have a main price graph.
[2017-08-17 23:37:23] |
Please correct my understanding. I am not sure what do you mean by "does not necessarily have a main price graph". In the Chart setting->Advanced Setting, Chart Region is set to 2. By doing this, is Main Price graph in the Chart Region 2 now? |
[2017-08-17 23:52:04] |
Yes but the drawing tool does not know that. Unless this worked previously, this is just not supported. There are no guarantees of proper functioning of the main price graph other than in Chart Region 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-18 13:07:02] |
We had a chance to look into this. We have already solved this so that the additional calculations for this drawing tool will be done in other chart regions when the main price graph is set to display in a different Chart Region other than 1. This will be out in the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-18 13:08:19
