Date/Time: Wed, 15 Jan 2025 12:40:40 +0000
Volume Profile Display Range
View Count: 829
[2017-08-17 15:17:30] |
User161390 - Posts: 16 |
Can you add a feature to "Display Entire Profile Range" - much like the feature to "Display Entire Profile High & Low". If high is 10 and low is 3, range is 7.
[2017-08-17 21:33:44] |
Notice: Suggestions (Currently not accepting)
