Date/Time: Wed, 15 Jan 2025 13:10:47 +0000
is this possible?
View Count: 932
[2017-08-17 15:08:44]
Glenn Infinity - Posts: 103
Do you know if there is a way to draw a line or level that only shows up in the right side fill space? and not in the rest of the body of the chart.
[2017-08-17 20:11:29]
ronnieb - Posts: 3
Use the stationary text tool and the underscore character to draw the line. The line can be moved to any where on the chart but you're limited to the underscore character.
[2017-08-17 20:46:59]
The response above was from a user.
Use the Line Drawing tool and then draw in the forward projection area:
Chart Drawing Tools: Forward Projection Area
Although as time goes by, this line is not going to always be in the fill space and eventually will be in the area where there are bars.
It sounds like you need to create a custom study to accomplish what you want:
Table of Contents | (Advanced Custom Study/System Interface and Language (ACSIL))
Date Time Of Last Edit: 2017-08-17 20:56:49
