Date/Time: Wed, 15 Jan 2025 13:06:36 +0000
divergence
View Count: 967
[2017-08-17 13:56:28] |
Deltareversal - Posts: 46 |
You have solution to plot auomatic line ( Delta Zone Support or Resistence ) in Cumulative delta and price when a divergence is determined as in my attached chart
InkedDivergenza_LI.jpg / V - Attached On 2017-08-17 13:55:40 UTC - Size: 896.37 KB - 367 views |
[2017-08-17 18:44:28] |
Not sure how well this would work, but have a look at using the Divergence Detector study: Divergence Detector Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
