Date/Time: Wed, 15 Jan 2025 12:55:34 +0000
Using Sierra Chart across multiple computers
View Count: 1701
[2017-08-17 13:37:39] |
User606491 - Posts: 164 |
I use Sierra Chart across multiple computers. Is there a way to sync my data files and configuration across all systems? Currently, I just copy/paste my data files, but my daily P/L does not transfer. Similarly, if I make configuration changes to general settings, I have to remember to replicate them on my other systems. As always, thank you for your response. |
[2017-08-17 14:52:03] |
No, this is not supported. Refer to help topic 15: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
