Date/Time: Wed, 15 Jan 2025 16:15:59 +0000
market orders from DOM
View Count: 1037
[2017-08-17 11:28:51] |
User884550 - Posts: 149 |
sometime when I buy inside ask or sell into inside bid my order is placed as stop instead of being immidiately filled at bid or ask pls advise if possible to fix somewhere in settings |
[2017-08-17 20:13:37] |
How are you submitting the order? If you are using the Chart DOM, then you need to configure the Order Inputs in the buy and sell columns so the price level is not relevant for order types. Refer to: Global Trade Settings Windows: Chart DOM Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-17 20:14:21
[2017-08-21 09:58:00] |
I am placing from trading DOM so do I understand correctly that order has to be defined as per last traded price, not by current inside bid/ask? |
[2017-08-21 20:43:14] |
Not exactly. Go through all of the Global Settings >> Chart DOM Settings >> Order Inputs* settings and set those as you require. Here is the documentation for those: Global Trade Settings Windows: Chart DOM Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-21 20:44:10
[2017-08-21 21:04:56] |
Here are the instructions: Global Trade Settings Windows: Setting Chart DOM Order Entry to Ignore Price When Determining Order Type Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
