Date/Time: Wed, 15 Jan 2025 17:35:12 +0000
FXCM LIVE TRADING DTC as to FXCM FIX TRADING
View Count: 874
[2017-08-17 09:14:27] |
User169391 - Posts: 62 |
I currently use the FXCM FIX TRADING service, is there any advantage in switching to the FXCM LIVE TRADING DTC service. What is the difference? Thanks. |
[2017-08-17 14:43:58] |
Yes, because there is not a large balance requirement and server-side OCO and bracket orders are supported. The FIX connection is no longer recommended. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-31 03:43:53] |
What is need to change from the FIX trading service to the DTC service? Are there any costs involved? I gather my interface and studies all remain the same. Thanks |
[2017-08-31 03:52:11] |
There are no costs involved. You just need to follow through the instructions here: https://www.sierrachart.com/index.php?page=doc/FXCMTrading.php#SetupInstructions The interface and studies will remain the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
