Date/Time: Wed, 15 Jan 2025 12:52:15 +0000
Data feed problem. Have pasted the message log below.
View Count: 792
[2017-08-17 07:06:47]
User169391 - Posts: 62
Delaying start of download for GBPUSD | 2017-08-17 17:01:13
DTC Client (74) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:01:14 *
DTC Client (74) | Initiating close of socket by core. | 2017-08-17 17:01:14
DTC Client (74) | Closed. | 2017-08-17 17:01:14
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:01:14
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:01:14
FXCM FIX Trading | Connecting to the server ds5.sierracharts.com. Port 10048 | 2017-08-17 17:01:16
DTC Client (76) | Creating socket. | 2017-08-17 17:01:16
DTC Client (76) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:01:16
HD Request # 33 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2017-08-17 17:01:23
HD Request # 33 | Download start date-time: 2017-08-17 13:12:05.000 | 2017-08-17 17:01:23
HD Request # 33 | Using server: ds5.sierracharts.com port 10150 | 2017-08-17 17:01:23
Socket (77) | Creating socket. | 2017-08-17 17:01:23
Socket (77) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:01:23
DTC Client (76) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:01:37 *
DTC Client (76) | Initiating close of socket by core. | 2017-08-17 17:01:37
DTC Client (76) | Closed. | 2017-08-17 17:01:37
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:01:37
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:01:37
FXCM FIX Trading | Connecting to the server ds5.sierracharts.com. Port 10048 | 2017-08-17 17:01:39
DTC Client (78) | Creating socket. | 2017-08-17 17:01:39
DTC Client (78) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:01:39
Socket (77) | Initiating close of socket by core. | 2017-08-17 17:01:43
HD Request # 33 | Error downloading historical Intraday data for GBPUSD. Timeout error connecting to server. | 2017-08-17 17:01:43
Socket (77) | Closed. | 2017-08-17 17:01:43
Historical data download thread signaled to stop. | 2017-08-17 17:01:43
HD Request # 33 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPUSD | 2017-08-17 17:01:43
HD Request # 34 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2017-08-17 17:01:43
HD Request # 34 | Download start date-time: 2017-08-17 13:12:05.000 | 2017-08-17 17:01:43
HD Request # 34 | Using server: ds5.sierracharts.com port 10149 | 2017-08-17 17:01:43
Socket (79) | Creating socket. | 2017-08-17 17:01:43
Socket (79) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:01:43
DTC Client (78) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:02:00 *
DTC Client (78) | Initiating close of socket by core. | 2017-08-17 17:02:00
DTC Client (78) | Closed. | 2017-08-17 17:02:00
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:02:00
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:02:00
FXCM FIX Trading | Connecting to the server ds5.sierracharts.com. Port 10048 | 2017-08-17 17:02:02
DTC Client (80) | Creating socket. | 2017-08-17 17:02:02
DTC Client (80) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:02:02
Socket (79) | Initiating close of socket by core. | 2017-08-17 17:02:03
Socket (79) | Closed. | 2017-08-17 17:02:03
HD Request # 34 | Error downloading historical Intraday data for GBPUSD. Timeout error connecting to server. | 2017-08-17 17:02:03
Historical data download thread signaled to stop. | 2017-08-17 17:02:03
HD Request # 34 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPUSD | 2017-08-17 17:02:03
HD Request # 35 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: fxcm | 2017-08-17 17:02:03
HD Request # 35 | Download start date-time: 2017-08-17 13:12:05.000 | 2017-08-17 17:02:03
HD Request # 35 | Using server: ds5.sierracharts.com port 10150 | 2017-08-17 17:02:03
Socket (81) | Creating socket. | 2017-08-17 17:02:03
Socket (81) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:02:03
DTC Client (80) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:02:23 *
DTC Client (80) | Initiating close of socket by core. | 2017-08-17 17:02:23
DTC Client (80) | Closed. | 2017-08-17 17:02:23
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:02:23
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:02:23
Socket (81) | Initiating close of socket by core. | 2017-08-17 17:02:24
HD Request # 35 | Error downloading historical Intraday data for GBPUSD. Timeout error connecting to server. | 2017-08-17 17:02:24
Socket (81) | Closed. | 2017-08-17 17:02:24
Historical data download thread signaled to stop. | 2017-08-17 17:02:24
HD Request # 35 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPUSD | 2017-08-17 17:02:24
HD Request # 35 | Intraday download COMPLETE for GBPUSD. Completion time: 20s. Unique request ID: 61 | 2017-08-17 17:02:24
Removed historical data download ID 61 | 2017-08-17 17:02:24
Real-time Intraday chart data file updates started for GBPUSD | 2017-08-17 17:02:24
Opened cached Intraday file: C:\SierraChart\Data\GBPUSD.scid | 2017-08-17 17:02:24
Intraday chart data file opened for GBPUSD | 2017-08-17 17:02:24
Delaying start of download for GBPNZD | 2017-08-17 17:02:24
Chart #1 has tagged chart #2 for full recalculation. Chartbook: GbpPairs.cht | 2017-08-17 17:02:24
GBPUSD [M] 0.00050 Range #2 | Performing a full recalculation because it has been tagged. Chartbook: GbpPairs.cht | 2017-08-17 17:02:24
FXCM FIX Trading | Connecting to the server ds5.sierracharts.com. Port 443 | 2017-08-17 17:02:27
DTC Client (82) | Creating socket. | 2017-08-17 17:02:27
DTC Client (82) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:02:27
HD Request # 36 | Downloading Intraday chart data for GBPNZD to the file GBPNZD.scid. Service: fxcm | 2017-08-17 17:02:36
HD Request # 36 | Download start date-time: 2017-08-17 13:12:05.000 | 2017-08-17 17:02:36
HD Request # 36 | Using server: ds5.sierracharts.com port 10149 | 2017-08-17 17:02:36
Socket (83) | Creating socket. | 2017-08-17 17:02:36
Socket (83) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:02:36
DTC Client (82) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:02:48 *
DTC Client (82) | Initiating close of socket by core. | 2017-08-17 17:02:48
DTC Client (82) | Closed. | 2017-08-17 17:02:48
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:02:48
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:02:48
FXCM FIX Trading | Connecting to the server ds5.sierracharts.com. Port 443 | 2017-08-17 17:02:50
DTC Client (84) | Creating socket. | 2017-08-17 17:02:50
DTC Client (84) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:02:50
Socket (83) | Initiating close of socket by core. | 2017-08-17 17:02:56
Socket (83) | Closed. | 2017-08-17 17:02:56
HD Request # 36 | Error downloading historical Intraday data for GBPNZD. Timeout error connecting to server. | 2017-08-17 17:02:56
Historical data download thread signaled to stop. | 2017-08-17 17:02:56
HD Request # 36 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPNZD | 2017-08-17 17:02:56
HD Request # 37 | Downloading Intraday chart data for GBPNZD to the file GBPNZD.scid. Service: fxcm | 2017-08-17 17:02:56
HD Request # 37 | Download start date-time: 2017-08-17 13:12:05.000 | 2017-08-17 17:02:56
HD Request # 37 | Using server: ds5.sierracharts.com port 10150 | 2017-08-17 17:02:56
Socket (85) | Creating socket. | 2017-08-17 17:02:56
Socket (85) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:02:56
DTC Client (84) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:03:11 *
DTC Client (84) | Initiating close of socket by core. | 2017-08-17 17:03:11
DTC Client (84) | Closed. | 2017-08-17 17:03:11
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:03:11
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:03:11
FXCM FIX Trading | Connecting to the server ds5.sierracharts.com. Port 443 | 2017-08-17 17:03:13
DTC Client (87) | Creating socket. | 2017-08-17 17:03:13
DTC Client (87) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:03:13
Socket (85) | Initiating close of socket by core. | 2017-08-17 17:03:16
Socket (85) | Closed. | 2017-08-17 17:03:16
HD Request # 37 | Error downloading historical Intraday data for GBPNZD. Timeout error connecting to server. | 2017-08-17 17:03:16
Historical data download thread signaled to stop. | 2017-08-17 17:03:16
HD Request # 37 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPNZD | 2017-08-17 17:03:16
HD Request # 38 | Downloading Intraday chart data for GBPNZD to the file GBPNZD.scid. Service: fxcm | 2017-08-17 17:03:16
HD Request # 38 | Download start date-time: 2017-08-17 13:12:05.000 | 2017-08-17 17:03:16
HD Request # 38 | Using server: ds5.sierracharts.com port 10149 | 2017-08-17 17:03:16
Socket (88) | Creating socket. | 2017-08-17 17:03:16
Socket (88) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:03:16
DTC Client (87) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:03:34 *
DTC Client (87) | Initiating close of socket by core. | 2017-08-17 17:03:34
DTC Client (87) | Closed. | 2017-08-17 17:03:34
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:03:34
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:03:34
FXCM FIX Trading | Connecting to the server ds5.sierracharts.com. Port 10048 | 2017-08-17 17:03:36
DTC Client (89) | Creating socket. | 2017-08-17 17:03:36
DTC Client (89) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:03:36
Socket (88) | Initiating close of socket by core. | 2017-08-17 17:03:36
HD Request # 38 | Error downloading historical Intraday data for GBPNZD. Timeout error connecting to server. | 2017-08-17 17:03:36
Socket (88) | Closed. | 2017-08-17 17:03:36
Historical data download thread signaled to stop. | 2017-08-17 17:03:36
HD Request # 38 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for GBPNZD | 2017-08-17 17:03:36
HD Request # 38 | Intraday download COMPLETE for GBPNZD. Completion time: 20s. Unique request ID: 62 | 2017-08-17 17:03:36
Removed historical data download ID 62 | 2017-08-17 17:03:36
Real-time Intraday chart data file updates started for GBPNZD | 2017-08-17 17:03:36
Opened cached Intraday file: C:\SierraChart\Data\GBPNZD.scid | 2017-08-17 17:03:36
Intraday chart data file opened for GBPNZD | 2017-08-17 17:03:36
Delaying start of download for AUDJPY | 2017-08-17 17:03:36
HD Request # 39 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-08-17 17:03:46
HD Request # 39 | Download start date-time: 2017-08-17 13:12:05.000 | 2017-08-17 17:03:46
HD Request # 39 | Using server: ds5.sierracharts.com port 10150 | 2017-08-17 17:03:46
Socket (90) | Creating socket. | 2017-08-17 17:03:46
Socket (90) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:03:46
DTC Client (89) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:03:57 *
DTC Client (89) | Initiating close of socket by core. | 2017-08-17 17:03:57
DTC Client (89) | Closed. | 2017-08-17 17:03:57
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:03:57
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:03:57
FXCM FIX Trading | Connecting to the server ds5.sierracharts.com. Port 10048 | 2017-08-17 17:03:59
DTC Client (91) | Creating socket. | 2017-08-17 17:03:59
DTC Client (91) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:03:59
Socket (90) | Initiating close of socket by core. | 2017-08-17 17:04:06
HD Request # 39 | Error downloading historical Intraday data for AUDJPY. Timeout error connecting to server. | 2017-08-17 17:04:06
Socket (90) | Closed. | 2017-08-17 17:04:06
Historical data download thread signaled to stop. | 2017-08-17 17:04:06
HD Request # 39 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AUDJPY | 2017-08-17 17:04:06
HD Request # 40 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-08-17 17:04:06
HD Request # 40 | Download start date-time: 2017-08-17 13:12:05.000 | 2017-08-17 17:04:06
HD Request # 40 | Using server: ds5.sierracharts.com port 10149 | 2017-08-17 17:04:06
Socket (92) | Creating socket. | 2017-08-17 17:04:06
Socket (92) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:04:06
DTC Client (91) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:04:20 *
DTC Client (91) | Initiating close of socket by core. | 2017-08-17 17:04:20
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:04:20
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:04:20
DTC Client (91) | Closed. | 2017-08-17 17:04:20
FXCM FIX Trading | Connecting to the server ds5.sierracharts.com. Port 10048 | 2017-08-17 17:04:22
DTC Client (93) | Creating socket. | 2017-08-17 17:04:22
DTC Client (93) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:04:22
Socket (92) | Initiating close of socket by core. | 2017-08-17 17:04:26
HD Request # 40 | Error downloading historical Intraday data for AUDJPY. Timeout error connecting to server. | 2017-08-17 17:04:26
Socket (92) | Closed. | 2017-08-17 17:04:26
Historical data download thread signaled to stop. | 2017-08-17 17:04:26
HD Request # 40 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AUDJPY | 2017-08-17 17:04:26
HD Request # 41 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: fxcm | 2017-08-17 17:04:26
HD Request # 41 | Download start date-time: 2017-08-17 13:12:05.000 | 2017-08-17 17:04:26
HD Request # 41 | Using server: ds5.sierracharts.com port 10150 | 2017-08-17 17:04:26
Socket (94) | Creating socket. | 2017-08-17 17:04:26
Socket (94) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:04:26
DTC Client (93) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:04:43 *
DTC Client (93) | Initiating close of socket by core. | 2017-08-17 17:04:43
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:04:43
DTC Client (93) | Closed. | 2017-08-17 17:04:43
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:04:43
FXCM FIX Trading | Connecting to the server ds5.sierracharts.com. Port 443 | 2017-08-17 17:04:45
DTC Client (95) | Creating socket. | 2017-08-17 17:04:45
DTC Client (95) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:04:45
Socket (94) | Initiating close of socket by core. | 2017-08-17 17:04:46
HD Request # 41 | Error downloading historical Intraday data for AUDJPY. Timeout error connecting to server. | 2017-08-17 17:04:46
Socket (94) | Closed. | 2017-08-17 17:04:46
Historical data download thread signaled to stop. | 2017-08-17 17:04:46
HD Request # 41 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for AUDJPY | 2017-08-17 17:04:46
HD Request # 41 | Intraday download COMPLETE for AUDJPY. Completion time: 20s. Unique request ID: 63 | 2017-08-17 17:04:46
Removed historical data download ID 63 | 2017-08-17 17:04:46
Real-time Intraday chart data file updates started for AUDJPY | 2017-08-17 17:04:46
Opened cached Intraday file: C:\SierraChart\Data\AUDJPY.scid | 2017-08-17 17:04:46
Intraday chart data file opened for AUDJPY | 2017-08-17 17:04:46
Delaying start of download for EURUSD | 2017-08-17 17:04:46
HD Request # 42 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2017-08-17 17:04:56
HD Request # 42 | Download start date-time: 2017-08-17 13:12:08.000 | 2017-08-17 17:04:56
HD Request # 42 | Using server: ds5.sierracharts.com port 10149 | 2017-08-17 17:04:56
Socket (96) | Creating socket. | 2017-08-17 17:04:56
Socket (96) | Connecting to IP: 204.15.192.106. | 2017-08-17 17:04:56
DTC Client (95) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2017-08-17 17:05:06 *
DTC Client (95) | Initiating close of socket by core. | 2017-08-17 17:05:06
DTC Client (95) | Closed. | 2017-08-17 17:05:06
FXCM FIX Trading | Disconnected from the server. | 2017-08-17 17:05:06
FXCM FIX Trading | Data feed disconnected. Will reconnect in 2 seconds. | 2017-08-17 17:05:06
[2017-08-17 07:44:17]
We are working on the problem. Allow a few minutes.
[2017-08-17 07:46:25]
This was a problem on the Sierra Chart side. It is now resolved.
We need you to follow the instructions here to update the symbol settings:
Global Symbol Settings: Update Symbol Settings
Be sure to follow the step to reconnect to the data feed. That is essential.
