Date/Time: Wed, 15 Jan 2025 13:08:32 +0000
Price Study Overlay format for Auto color of Last value based on slope of value
View Count: 997
[2017-08-16 21:54:28] |
User686802 - Posts: 69 |
Hi, using Price/Study Overlay (see setting file sc_slop1). When I set HLC bar, the Last value has option for Auto color (high / low) based on slop, but it doesn't work, it defaults to the high color even while the slope is down! (see file sc_slop2). When I set to Line on Close, then the Auto color (high /low ) works perfectly for Last value, when slope is up the high color is use and when slope is down the low color is use, (see file sc_slop3). So I would like the HLC bar to Auto color base on slope just like the Line on Close. Thanks, I thinks it should be easy for you to test, and hopefully to fix.
sc_slop1.PNG / V - Attached On 2017-08-16 21:50:14 UTC - Size: 26.15 KB - 338 views sc_slop2.PNG / V - Attached On 2017-08-16 21:50:23 UTC - Size: 29.94 KB - 282 views |
[2017-08-16 21:55:27] |
the third screenshot refer to previously was missing, so here it is
sc_slop3.PNG / V - Attached On 2017-08-16 21:54:47 UTC - Size: 29.71 KB - 361 views |
[2017-08-17 17:59:08] |
I got no reply from above two posts, please read and let me know!
[2017-08-17 19:50:26] |
Please be patient, you need to allow time for us to understand and look at this, and sometimes with our long task list, we may not even get to this until two years later. So you should allow up to 2 to 3 years for future requests. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-17 19:50:50
[2017-08-17 20:02:47] |
Looks like a bug, since the Auto color field is available in the "HLC bar" and it is available for "Line on Close", that's why I sent you a screenshot of the bug. Why are you replying it is a new feature?
