Date/Time: Wed, 15 Jan 2025 13:06:17 +0000
acsil based attached orders moving with parent
View Count: 1089
[2017-08-16 19:17:11] |
onnb - Posts: 662 |
I do following 1. Submit parent order + OCO from ASCIL 2. The OCO's are set as prices (not offset) 3. I then move the parent order on the chart (it has not been filled yet) I see the child orders adjust Is that expected? Is there any way to disable that behavior? |
[2017-08-16 19:44:22] |
Yes, this is expected and there is no way to disable this. Although you set the attached orders as prices, they are converted back to offsets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
