Date/Time: Wed, 15 Jan 2025 12:56:46 +0000
adding new time frme button
View Count: 792
[2017-08-16 19:02:47] |
User630989 - Posts: 10 |
I have found where to add new time frame buttons to status bar... I want 3 minute,,, but that is not a choice I can select ... please advise
[2017-08-16 20:49:10] |
Refer to: Control Bar: Custom Buttons for Intraday Chart Bar Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
