Date/Time: Wed, 15 Jan 2025 12:33:36 +0000
Cannot connect to Bitfinex
View Count: 2119
[2017-08-16 18:54:43] |
User833972 - Posts: 6 |
Hello, I'm trying to login to Bitfinex via SierraChart, but always I end with yellow box, showing "Connecting". Do you have any ideas, how to solve the problem? I add screen with message log. Thank you very much for any ideas and help. Have a nice day! |
sc_bitfinex.jpeg - Attached On 2017-08-16 18:54:13 UTC - Size: 316.53 KB - 344 views |
[2017-08-16 21:00:28] |
This is not supported. You can just access the data only. Refer to: https://www.sierrachart.com/index.php?page=doc/Bitcoin.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-17 05:15:52] |
Thank you very much! Have a nice day :)
