Date/Time: Wed, 15 Jan 2025 12:53:20 +0000
Record Market Depth Data - using two computers
View Count: 1561
[2017-08-16 13:19:03] |
nicktrader - Posts: 728 |
I am using a PC and in some cases a laptop for SC. But most of the time the PC is LIVE online. For more detailed information some I enabled the option "Record Market Depth Data" for some futures (==>> for replay function purposes). Is it possible to use the "PC" data for my laptop and if Yes - how. |
[2017-08-16 20:21:03] |
We are not sure we understand the question. The closest that is available is what is documented here: Using DTC Server for Data and Trading in Another Sierra Chart Instance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-17 04:29:09] |
Okay, sorry for my English. Replaying Charts: Replaying Trade DOM Windows The instruction says: Enable the Record Market Depth Data option if you want to be able to replay the market depth data on the Trade DOM. Market depth data will only be recorded as of the time that this option is enabled..... Are the data recorded in a specific file and I can copy that file to my laptop or how does it work? |
[2017-08-17 05:54:32] |
Yes, you can copy the market depth data files between your computer systems. That is not a problem. The folder is: \Data\MarketDepthData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
