Date/Time: Wed, 15 Jan 2025 15:34:39 +0000
Ray tool bug?
View Count: 897
[2017-08-16 07:10:26]
JRA - Posts: 97
When I draw a line with the horizontial ray tool, and then cut that line at a later point (say 5-10 bars), then the line can not be moved up or down.
[2017-08-16 21:35:19]
We will check on this.
[2017-08-18 05:49:46]
We cannot reproduce what you are describing.
Follow the instructions here to move the drawing:
Chart Drawing Tools: Move Drawing
[2017-08-18 06:26:17]
JRA - Posts: 97
you are right I was clicking on the anchor point. If I click anywhere between the line it moves.
