Date/Time: Fri, 02 Oct 2026 18:02:56 +0000
Trying To Get Color Through sc.Input
View Count: 1821
[2017-08-16 01:22:57]
CustomIndicators - Posts: 126
When I call to get the color from my input, it seems to be returning 0. When I take a peak at the study settings once loaded onto a chart, I'm finding that the color setting is set to black. You can clearly see in my code, I didn't set that to black. What is going wrong?
Here are portions of my code:
const int HMH_COLOR = 10;
SCSFExport scsf_Study(SCStudyInterfaceRef sc)
  SCInputRef HMHColor = sc.Input[HMH_COLOR];
  if (sc.Defaults)
    HMHColor.Name = "Background Color When Over Extended Up";
    HMHColor.SetColor(RGB(255, 255, 255)); // White
  if (sc.Subgraph[OSCILLATOR][sc.Index] > sc.GetPersistentFloat(PEAK_ONE))
    // Tried this: Returns 0
    unsigned int color = sc.Input[HMH_COLOR].GetColor();
    sc.ChartBackgroundColor = color;
    // Tried this too: Returns 0.
    unsigned int otherColor = HMHColor.GetColor(); // <- Just so I can see the returned value
    sc.ChartBackgroundColor = HMHColor.GetColor();
Date Time Of Last Edit: 2017-08-16 01:23:37
[2017-08-16 02:22:13]
We see no problem when testing it with the following code:
SCSFExport scsf_TestFunction4(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "Test Function 4";
    sc.AutoLoop = 0;
    sc.FreeDLL = 0;
    sc.GraphRegion = 0;
    sc.Subgraph[0].Name = "Test";
    sc.Subgraph[0].DrawStyle = DRAWSTYLE_LINE;
    sc.Subgraph[0].LineWidth = 2;
    sc.Input[0].Name = "Color";
    sc.Input[0].SetColor(128, 128, 128);
    return;
   unsigned int ColorValue = sc.Input[0].GetColor();
Also this code block in your function is missing a return:
if (sc.Defaults)
Date Time Of Last Edit: 2017-08-16 02:23:16
