Date/Time: Sun, 13 Sep 2026 07:48:37 +0000
Issues with sc.GetBasicSymbolData
View Count: 4713
[2017-08-15 21:19:30]
T29_Dev1 - Posts: 22
We started using GetBasicSymbolData and we have a few issues with it:
1. s_SCBasicSymbolData::PriceFormat contains incorrect price format (for ex. I saw 4950 instead 2)
2. I can't see L2 in s_SCBasicSymbolData until I open DoM window for the symbol
3. it's working on 1568 and not working on 1598 version - all fields in s_SCBasicSymbolData == 0
[2017-08-15 21:42:25]
1. This does not make sense. There must be some structure member misalignment. Make sure you are using the current Sierra Chart header file, and using the current version of Sierra Chart. There should be no trouble with this whatsoever.
It is simply impossible for there to be anything functionally wrong with this in Sierra Chart. We see no reason to even run a test because we know everything would work correct with this.
2. Yes this is correct.
You need to set:
ACSIL Interface Members - Variables and Arrays: sc.UsesMarketDepthData
3. Sierra Chart needs to be connected to the data feed and you need to be using a symbol that provides current quote data from the data feed. Also make sure you recompile the study function for the current version. It will not work if compiled before version 1576 and a notice is provided about this.
Date Time Of Last Edit: 2017-08-15 21:54:59
[2017-08-15 22:34:07]
onnb - Posts: 666
We need to subscribe to many charts for L2 data. Using the method above, we would need to add a study to each chart.
Is it possible for you to add an api to set that for a remote chart?
Date Time Of Last Edit: 2017-08-15 22:36:04
[2017-08-15 22:41:00]
OK we know how to solve this. We will add another integer flag variable to the function to request the market depth data.
Really we have to create a new function for this.
Date Time Of Last Edit: 2017-08-15 22:41:40
[2017-08-17 19:57:57]
onnb - Posts: 666
following up on #1 / #3
#3 works ok after recompile
#1 - we will follow up on this after further testing on our end
OK we know how to solve this. We will add another integer flag variable to the function to request the market depth data.Really we have to create a new function for this.
In which build is this?
[2017-08-17 20:07:44]
This will be in version 1599.
[2019-05-04 13:09:46]
TedMar - Posts: 191
its this funktion sc.GetBasicSymbolDataWithDepthSupport ?
how i can access to Symbol DepthLevels?? i can nothing find in s_SCBasicSymbolData
Date Time Of Last Edit: 2019-05-04 14:10:35
[2019-05-06 20:38:56]
You can use that function but this really is the newer one:
sc.GetSymbolDataValue(SymbolDataValuesEnum ValueToReturn, const SCString& SymbolForData = SCString(), bool SubscribeToMarketData = false, bool SubscribeToMarketDepth = false);
Did you want to access market depth data for a different symbol or the symbol of the chart the study is applied to?
[2019-05-06 22:31:33]
TedMar - Posts: 191
i want market depth data for a different symbol , like s_SCBasicSymbolData structure.
[2019-05-07 04:41:41]
Ok we will need to add new ACSIL functions to support this.
[2019-05-08 21:01:22]
Ackin - Posts: 1865
that would be useful
+1
[2020-09-27 02:50:50]
onnb - Posts: 666
Should the above function be working in replay?
[2020-09-27 09:27:30]
The answer is yes but we need to know what the specific issue you are having is.
[2020-09-27 16:51:11]
onnb - Posts: 666
double ask_price = sc.GetSymbolDataValue(SymbolDataValuesEnum::SYMBOL_DATA_ASK_PRICE, "EURUSD", true, false);
I'm making this call and getting return value 0.
I tried this both on the same symbol that the chart is applied to and a I tried a remote symbol with same result.
[2020-09-27 22:48:56]
onnb - Posts: 666
One more note, connected to a live feed it works fine
[2020-09-28 10:05:48]
We cannot reproduce any problem with this. During a chart replay that line of code does provide a value. And yes you must be connected to the data feed because that is where the data is coming from.
