Date/Time: Wed, 15 Jan 2025 12:56:40 +0000
trading size limit
View Count: 812
[2017-08-15 19:37:41] |
User544873 - Posts: 1 |
Hello, Is there a way to set a maximum amount of futures contracts that can be held at the same time? As a way of risk control. Kind regards, Oliver |
[2017-08-16 20:22:44] |
The closest Sierra Chart has available to this is documented here: Global Profit/Loss Management Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
