DTC Protocol Discussion Forum
Date/Time: Tue, 04 Nov 2025 15:12:32 +0000
Inside bar
View Count: 4401
[2017-08-15 18:28:34]
User66360 - Posts: 81
Can anyone code an indicator for if a candles closes inside the range of the previous candle? Using a paint bar?
It would be similar to an inside bar, but only the close matters.
[2017-08-18 05:41:23]
DTC Engineering - Posts: 320
You have posted on the wrong message board, you need to post here:
https://www.sierrachart.com/SupportBoard.php
