Date/Time: Wed, 15 Jan 2025 12:48:44 +0000
Control Bars
View Count: 887
[2017-08-15 14:13:28] |
rc7rader - Posts: 144 |
Are the control bars configuration saved in a file that can be backed up? I'm planning to do a clean reinstall of windows and reinstall all apps. I want to save some of the configurations I made in Sierrachart. Thanks. |
[2017-08-15 14:17:51] |
Yes. Refer to step 5 here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation And refer to: Software Download: Making a Backup of Your Sierra Chart Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-15 14:18:45
