Date/Time: Wed, 15 Jan 2025 21:57:05 +0000
Pending Order Alert
View Count: 1558
[2017-08-15 11:33:53] |
User287992 - Posts: 51 |
Hi, there are alerts for order filled, order canceled, target filled and stop filled, do you think you could add one for "order pending"? It's quite handy for algo trading. Thanks. |
[2017-08-15 17:09:28] |
No, because this is not a clearly defined event. Or at least we are not really sure what you are referring to. Anyway, it is not something we would add. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-15 17:09:52
[2017-08-16 11:59:53] |
Ok, to be more specific - I am talking about sound alert that plays specific preset sound file everytime there is an order placed. For example ninjatrader has this feature when it simply says "Order pending". So basically if "order canceled" alert is triggered when any order disappears, "order placed" alert should be triggerd when any order appears. Is that something that could be added? |
[2017-08-16 22:29:51] |
Sawtooth - Posts: 4153 |
Cell J4, of the Spreadsheet System for Trading study, goes non-zero when a pending order is placed, i.e. a limit or stop order, so this type of event is defined. An alert could be created from this change of state using a spreadsheet formula.
[2017-08-18 17:19:30] |
This will be supported in the next release.
[2017-09-25 15:03:13] |
Hi, just wanted to ask how does it look with adding the alert? Thanks |
[2017-09-25 17:28:17] |
This was added about a month ago. It is in Global Settings >> General Trade Settings. You will need to update Sierra Chart: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-09-25 17:29:04
