Date/Time: Wed, 15 Jan 2025 12:58:51 +0000
Bitmex chart not displayed in trading DOM
View Count: 1728
[2017-08-14 20:13:37] |
User248078 - Posts: 2 |
Good afternoon, I recently joined Sierratrading and I am trying to make it work with Bitmex. Followed all steps on how to setup an account with the trading feed and it connects perfectly. The issue is when trying to launch the trading DOM the chart is not displayed (Please see screencap below). I hope you can bring me some light on how to solve this. Thank you for your support. http://www.sierrachart.com/image.php?Image=1502741147728.png |
[2017-08-15 12:56:09] |
Hi, Just tried doing the same with the Testnet and I do get the same screen on the Trading DOM. Somehow the chart is not plotted. Any similar cases? I just sent you the log, I hope you can help. thank you. |
[2017-08-15 16:48:35] |
The Trading DOM does not support a chart. You just need to open a normal chart through File >> Find Symbol and enable the Chart DOM as explained here: https://www.sierrachart.com/index.php?page=doc/ChartTrading.html#ChartDOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
