Date/Time: Wed, 15 Jan 2025 12:43:05 +0000
Chart Not Responding
View Count: 904
[2017-08-14 17:46:11] |
User103861 - Posts: 42 |
I am having trouble with one chart, one symbol, $DOWT (I have subscribed to the real time Dow Jones Index Data). Each time I attempt to do anything in this chart (add drawings, change timeframe, etc) I get "Not Responding" from Windows and have to close Sierra Chart. This is the only chart/symbol out of many that I have any issues with. I attempted to create a whole new chartbook with 1 chart, just this symbol and have no problems at all so it seems to be just one chartbook. Please advise how to fix.
[2017-08-14 19:47:21] |
We recommend closing that chart, and just opening a new one for that aim symbol. Although you could check the Chart >> Chart Settings >> Tick Size setting and make sure it is set to 1. The problem might be related to that. Although this would only affect certain types of studies, aand not Chart Drawings. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
